Platinum Lp
Posted by: allthingsanalogue on 15 October 2008
Just crious if a platinum LP, the ones you buy in a frame that are silver or gold can be played and do they really have the music actually on them, if so, do they sound any better?
Posted on: 15 October 2008 by winkyincanada
My understanding is that they may have music on them. It might not actually be the record that it purports to be. You can play it. It sounds shite in any case. It might wreck your cartridge.
Posted on: 16 October 2008 by allthingsanalogue
Well, I don't have one I was just curious.
Posted on: 16 October 2008 by John M
doh!!!!
