Tracking Weights, advice needed.
Posted by: woodface on 15 November 2001
I have recently become the proud owner of an ekos tone arm; this has replaced my previous ittock. I believe the settings have remained the same accross the two arms but cannot be sure. I have an OC9 cartridge with is set at 1.75 gm tracking and level three on the bias control. In some cases the attack does not seem as pronounced (especially with Coltrane) and so I am wondering whether the tracking is set too high or too low? I am not one of lifes tinkerers and the overall balance seems correct on Modern recordings but a bit light on Jazz etc. Advice would be most welcome? Lastly if you adjust tracking do you have to adjust bias accordingly?
Posted on: 15 November 2001 by Craig B
on Linn's tonearms (and most others) anti-skating compensation (AS) should be set to the same value as vertical tracking force (VTF) as a starting point. Linn don't go any further than this in their description of AS optimisation, however, some fine tuning can generally make an appreciable difference. The purpose of all this, by the way, is to achieve equal tracking of both sides (channels) of the groove wall.
The most widely accepted technique for fine tuning AS is to use your own hearing. Using a record that has a variety of instruments and signal levels (a test record can be helpful), listen for poor sound quality/tracking in one channel vs. the other. If certain instruments seem to breakup occasionally in the left channel for example, then a slight decrease in AS is required. Conversely, if you detect problems in the right channel, then slightly more AS is needed. Generally the best setting is not too far from the recommended amount if your platter is properly level.
I have noticed over the years that the best AS setting usually corresponds with the cantilever remaining straight inline with the cartridge body when viewed from the front during play. This assumes that your platter is perfectly level, your cartridge is properly aligned, and your stylus is not bent or otherwise out of close alignment with the cartridge body when not under load.
You will find that when viewed from the front, the cantilever will appear to point inwards toward record centre when you increase AS and point outwards when you decrease AS. Adjusting AS until the cantilever appears centre aligned generally results in the best tracking of both channels.
Craig
Posted on: 15 November 2001 by Duncan Fullerton
I'd always setup my AS to the same as the tracking force. Having sent my Troika off for a re-tip I've been told it's got a pronounced "lean" on it now and needs straightening out.
Thanks for your setting up tips, I'll try them when the cartridge is back.
Posted on: 15 November 2001 by woodface
Looks as though the AS could be the culprit, I will have a play!
Posted on: 16 November 2001 by woodface
I have adjusted the AS (it was actually set at 1.5 gm) and the sparkle has returned alongwith all the inherent ekos strenghts.
