Help with i-tunes & external hard drive
Posted by: Nigel 66 on 04 August 2009
Dear all
I hope that this is the right place for this post.
I have just bought a new laptop following the 'death' of my last one. My problem is that I have some 700 cds stored in a lossless format to an external hard drive, but when using my new laptop, it doesn't seem to be able find the tracks. Also, when I've tried to 'rip' any new cds to i-tunes, it saves it to the laptop's internal memory, rather than the external drive where my existing i-tunes library is.
Can anyone help, and if they can, please can you keep any explanations/instructions simple (like me) as I am not particulalrly pc literate.
Also, I'm at work at the moment so won't be able to try the fixes, until later this evening.
Thanks alot.
Posted on: 04 August 2009 by Nigel 66
Oops - I probably should've mentioned that I'm using windows rather than a mac.
Posted on: 04 August 2009 by Eloise
First, in <Preferences><Advanced Tab> you need to change the location to save the files to your external drive (probably something like e:/iTunes/iTunes Music)
Then open an explorer window, and drag the folders containing your music files into the iTunes window (to where it says library).
Hope this helps ... sorry doing it from memory for Windows so location of your music maybe slightly different.
Eloise
Thanks Eloise.
I'll try this when I get home. It's been getting frustrating as I've tried a few things, none of which worked, and I didn't want to have to start ripping the c8,000 tracks all over again ! !
Posted on: 04 August 2009 by MrPlanner
you'll also need to make sure that your folder is shared on the network
Posted on: 04 August 2009 by Former member
You don't need to share the folder if the external drive is directly connected to your laptop.
Also, if the files are in a folder on the external drive all you have to do is point itunes to that folder. Restart itunes, which should then rebuild the library.
If it doesn't, then follow Eloise's advice, or from the itunes menu choose File>add folder to library, browse to the external drive where the files are and click OK.
Thanks for the replies. I will try these when I get home and hopefully all will be well !
Finders crossed.
Just another thought - try holding down <shift> as you double click the iTunes icon to start it. You'll be given the opportunity to create or open an iTunes Library - browse to your external disk and see if there is another Library on the external disk - this only works if the drive letter is the same as it was on your old computer.
Eloise
Posted on: 04 August 2009 by pcstockton
File, add Folder (Or Location). Done
Posted on: 05 August 2009 by Nigel 66
Dear all
Thanks for the help. Tried this last night, and although it took several hours (my i-pod saw this as a new library, and it had to delete it's contents and reload all 8,000 tracks)it did work.
I can now rip the new cds I've bought, using a better/faster laptop.
Job done, so thanks again.
Posted on: 05 August 2009 by pcstockton
iTunes is so f-ing lame.... I am forced to use it due to having an iPhone, but I dread it every time.
I went through the painstaking effort of creating custom ringtones only to find that because they were deleted from my hard drive, they were deleted from my phone.
Come on!!! They are ring tones. I made them. They are mine.
Unfortunately a folder that contained them was deleted. When I hooked up my iPhone and was going to put some new music on it, iTunes demanded that I also sync my ringtones. Demanded. I didnt want to sync them so I un-checked "Sync Ringtones" then an error comes up and states if I dont sync, it will delete them from my iPhone.
So i try to sync.... And it cant find the ringtones on my PC, so it proceeds to delete them from my iPhone.
This is the most ridiculous things ever. How have they sold millions of iPods???
Posted on: 05 August 2009 by garyi
Oh the humanity!
