52 tweaks
Posted by: Paul B on 20 April 2001
A question though. The locking collars on the Burndy cables - should they be locked tight or...?
Can I safely assume that the usual warm-up & break-in improvements will also occur over the next few weeks?
Any other 52 tweaks/suggestions appreciated.
Paul
Ninety nine plus percent of the vast superiority of the 52 over the 102 will be heard regardless of what 'tweaks' are done or not. And at this phase you probably would not be able to tune into them as a suboptimally installed 52 would absolutely slay a perfectly set up, manaed-to-the-attic 102. Later (much later) on, if you must you can try the 52 using only a single input connected (into input 3), with slackened locking collars, having the rec out muted and so on.
The best way to tweak the 52 is to simply listen to it.
Ron
Dum spiro audio
Dum audio vivo
1) If input 1 is unused take out the straight through boards (i,e have nothing in input 1)
2) Like Ron my Burndies are not done up so they are locked (likewise on my CDS2)
3) Put the record mute on.
4) Make sure the 52 is decoupled from its support (an isolation table or dedicated table of some sort) - I use a custom modified Projekt support.
5) Try damping the case with a aluminium weight (i have used a aluminium cat in the past). This gives varying results based on the application. I don't use anything now but it's worth experimenting.
6) Keep the 52 as far as humanly possible from powersupplies.
Hope this helps,
Dev
Congratulations on your 52. I also made the step from 102 to 52 and the difference was mind boggling. I still rate it as the highest naim upgrade I made (Albion/ACt 2 upgrade not included), closley followed by CDX/XPS to CDS2 and 102 no cap to 102 supercap. The vibrancy, life and clarity of the 52 is astounding. Suddenly so much made sense in the music. I did find that the 52 prefered being on the stiffest support possible as opposed to supports on the more squishy side. This meant replacing the rubber feet in my WB Asside with ball bearings. This move, however, had the opposite effect on items with power supplies. But I made this change a good 9 months after owning the 52. The 52 seems to make all sources sound better and took even a modest rega radio to electrifying heights.
dave
You mean tweaks for a 52.
1. Make sure that it's 100% level
2. Try it on a good support (I use Mana)
John
Is it worth the effort for a CD player ?
Peter
John
