Snip!
Posted by: Duncan Fullerton on 04 October 2001
And I know a bit of card in front of the 32.5 would save me the hassle, but then I wouldn't be able to look at it!
I'm no electronics expert but this 'snipping' of the cable sounds a little too risky to me. Hope you get an experts view on this soon before you fcuk it up!!
Cheers Mad Matt
Judd
cheers
Nigel
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
Put a bit of black tape over it
I've covered mine with red tape. If you cut it carefully around the bulb it looks like it's off.
I experimented and found that black tape sounds worse than red. Naturally, if your 32.5 has a green led you'll have to use green tape. I don't know how the green tape sounds. ![]()
Brian
Hmmm. Maybe Peter Belt has some Quantum Doppler Foam Film (tm) that will shift the LED from glaring green to relaxing red. This may also rid my poor old 32.5 of any nasty morphic resonances it has from being fed by a Linn CD player in an earlier life!
But seriously ... Justin, I presume you are talking about a shunt resistor. What sort of values should I start with? I'm no good at electronics, but I can solder.
[This message was edited by Duncan Fullerton on THURSDAY 04 October 2001 at 17:42.]
If you DO snip, try out your 32.5 with the light snipped. And by all means let us know if there is a sonic difference.
- GregB
Insert Witty Signature Line Here
quote:But tidy-up any loose-ends
Perfectly safe
Allan
[This message was edited by sceptic on THURSDAY 04 October 2001 at 20:02.]
The leads could easily be bent so it was hidden behind the front panel.
Don't know if the 32.5 would be the same.
cheers, Martin
Brian
Greg, if I can hear a difference I will hire myself out as a "Golden Ears"! ![]()
Don't snip it.
If you think it is better it will be illusory, and it will look limp, lifeless and disappointing.
....and it won't improve your preamp either!
Chris ![]()
They can be purchased in difference brightness, they range from 5-15 mCd right through to 6,500 mCd.
The other option is to change the value of the series resistor.
Naim Collector....
If you change the led, bear in mind they come in many types, transparent, translucent or cloudy; narrow or wide beam;low/med/high/v.high brightness, as well as different sizes.
In this case, keep pliers on the led lead out wires between the led and the heated tip to act as a heatsink while soldering in the new led.
Keep the original so that it can be returned to original condition to preserve resale value.
