What are the differences between the 42 and the 42-5?
Posted by: DeonC on 01 October 2003
Hi guys
I got the 42 today. The serial number is 9163, and that makes it a 1983 vintage.
What I would like to know is what are the differences between the 42 and the 42-5? I know the 42-5 works off dual supplies and the 42 off a single rail supply, but how does one go about upgrading from 42 to 42-5? Is it a total replacement of the PCB and internals, or are there smaller differences (i.e. things that I can DIY)?
I must say that it is very impressively built. A solid metal chassis, and it looks MUCH better in-the-flesh
Thanks for the comments so far.
Deon
PS. I got an LP12 hybrid too (it seems to have the heavier AR platter), and I will start using that at some stage too- I first need to have the armboard drilled to fit a tonearm, and she needs a PSU. Now if I could only pick up a pair of Naim amps 2nd hand...
__________________________________________
Life is not measured by the number of breaths we take,
but by the moments that take our breath away.
- Author unknown
Deon
- Author unknown
