Low-level listening problems with 102/180 combo
Posted by: Gavin on 10 September 2002
I posted this in another thread a while ago, but it seems to have been passed by! Still wonder if anyone can help...
I'm hoping somebody might be able to shed some light on a minor quibble I have with my 102/180 which is as follows:
7 o'clock on the 102 is zero (almost!). If I turn the volume up slightly, I get only the l/hand channel. It's only when I get toward the 8 o'clock mark that the r/h channel decides to make music. Sometimes it's not practical to have my music at volume I want(ie low), and there is a minimum volume I have to hit before things 'even up'.
I never noticed it with the Kef Concertos, only since I got the Celestion A2s, which are 4 ohm imp, sensitivity = 96dB, where the Kefs were about 88dB I think, and also an 8 ohm load. Are things just getting louder quicker because of the speakers? Is there a fault with the setup? Most importantly, what can I do to sort it?
I have tried powering down and giving the volume pot a brisk up/down to see if there is dirt or dust on the inside, but to no avail...
Gav
Gav
