Steve Hall
Sit back and enjoy, and dont be tempted to change stuff until you know this setup as well as your first.
As i've now moved on to CDX/52/Super/Naxo/Hi/2x180/sbl's
Will do, I'm looking at speakers, a cdx and stands as the next areas of improvement, although I'm not going to start off the great stand debate
So, how does the 2x180's compare to a 250?
herm
So what's the difference like?
Well, I find it hard to put into words, especially in the detail some people on here are capable of, but the bass is much tighter and controlled, and it seems less of an effort at high volumes. Also I find that I don't have to crank up the volume to hear the detail, it's all there at low levels. Very impressive.
Steve Hall, sell your CDX to Shinpad, and put the proceeds towards a CDS2. Both of you will then really gasp with joy!
Sounds like a good idea! I don't think it's a mullet until I'm happy to leave the system as is - well that's my excuse, and I'm sticking to it
If I do move to a CDX can I power it with a Hi-Cap, or do I need to use the XPS?? Is the XPS for the CDX the same as the one used for the CDS2??
Graham
