allae positioning...
Posted by: ken c on 19 May 2001
so, will this be the first naim speaker that can be used against the wall as well as out into the room??
interesting.
enjoy...
ken
The sbl and dbl are the only models which must be placed hard up against a wall. I would not suggest that the others work in free open air but they can all work happily some space away from the boundary depending on the room.
Also, what is the minimum power amp? 150, 140, 180 or 250?
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
In another thread Paul gave the following answer to your first question:
End of July, early August. We have finished our work, we now have to wait for our cabinet manufacturers to wake up!
Ciao!
Willem
No, the same is true of the Intro, Credo and NBL.
paul, many thanks for correction
enjoy
ken
Bruce
I downloaded the manuals as well, but didn't spot the NAP 6-50 and the IXO 2 immediately. I only noticed this RC 5 connection on the NAT 05 and was wondering why it's there and why only on the NAT 05 and not on the CD 5 or Nait 5. "Multi-room" control was really the last thing I expected from Naim, but it seems that Naim is taking a new, less purist direction with the 5 series. Naim introducing an audio-visual and multiroom amplifier "designed to work with long speaker wires of any manufacture"? If you would have predicted it a year ago, people would think you're joking! I'm curious to see if any of these new "features" will appear as well in the higher end gear.
Ciao!
Willem
Many of our customers wish to have the naim family sound in more than one room, this has been possible but a little tricky to achieve.
THe nap6-50 is a pure 6 channel,3 zone amp that makes music. It is not in the Series5 casing.
It is housed in our full size extrustion and is fan cooled.
We do not produce any controllers but have found our amp works very well with the QED systemline system. If any of our customers wish to have a multizone set up, they can now use a Naim amplifier, but with a Systemline front end. Elevator music a thing of the past. If that's what takes your fancy!
Thanks for the info! Very interesting. I first noticed the extra socket in the review of the NAT 05 by Paul Messenger in Hifi+, then I saw it again after downloading the Tuners manual. Funny nobody mentioned this socket earlier. By the way, good idea to put the manuals in PDF version on the Naim website. Had a look at the Fraim manual as well and I have to admit, it looks interesting. I'm looking forward to hear the stands. Any idea if they'll be at the High End in Frankfurt? I will come together with Marc, colleague and fellow Naimophile, on Friday the 15th of June. Hope to see you (all) then!
Ciao!
Willem
Judd
enjoy...
ken
Judd
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
We feel we have designed a very exciting alternative with the allae, extremely musical, user friendly and appealing styling. It is also not so wall dependant as the sbl, a real issue for many people.
I'm looking forward to it!
Ciao!
Willem
downloaded naim manuals refer to IXO2
the downloadable Naim manuals on the main Naim site refer to IXO2, so presumably a new low-end active crossover is in the pipeline...
Where are the downloadble manuals? I couldn't find them...
Stephen Bennett. Composer and sound design. (UK)
http://chaosstudios.gen-next.com
henry fool http://www.collective.co.uk/henryfool The Fire Thieves: http://tft.gen-next.com
Author of 'The Fast Guide To Logic' http://www.pc-pubs.demon.co.uk/fgel.htm
and 'Making Music with E-Magic Logic Audio http://www.pc-pubs.demon.co.uk/mmela.htm'
Select a product like for instance the Fraim (Products/Accessories/Components/Fraim). At the bottom of the page you will find the link "Download an Owner's Manual" which will bring you to the "Manual" page.
Ciao!
Willem
