Hummmmmmmmmmmmmmmm
Posted by: seagull on 17 June 2002
I recently moved my kit which entailled disconnecting everything and reconnecting again (including power off and on using the prescribed order).
Since then I have been getting slight mains hum (audible with the volume at 12 o clock - louder than I usually listen I know but...) but only when the phono is selected (LP12 connected). I have tried the connections again but the hum has not gone away. Any ideas?
Also, I connected the speakers up so the cable from the right hand side went to the right hand speaker (as you look at them from the listening position) and the left to the left. However, when I turned the balance control to the right the left speaker stayed on and vica versa.
. Is this normal or was the balance control wired by a girlie?
