Path forward... recommendation welcomed
Posted by: Roland Huu on 24 March 2001
I'm in a 'spot' the moment. At the moment I have the following...
1. Nait 3
2. CD3.5
3. FlatCap for CD3.5
4. Intro II speakers
I've plans to upgrade the Nait3 to a pre/power combination. However I discovered that the 92/90 combination is no longer available. This afternoon I heard the new NAC112/NAP150 with my CD3.5+Flatcap at my dealer.
I was rather dissapointed. My old combination sounded better.
I'm going to listen to the setup again 3 days from now to see if the sound improves after a couple of days
of run in (although not quite enough) or I just don't like the sound of the new 112/150 combination.
If the latter is the case what are my options if I do not choose 112/150?
Should I convert my Nait3 into a pre-amp and use it with a NAP180? Has anyone done that before? I could later added a HiCap to the pre-amp.
Roland
