Auto in Mode select
Posted by: Cjones on 05 May 2005
Just wondering, now that I have a couple sources, I need to switch from output mode depending on source. What are your experiences with auto? Do you find that it does not always pick the "right" one?
Posted on: 05 May 2005 by Manu
Auto works well (assumming you refer to the AV2). Except (not the AV2`s fault) when you have a 2 channel only Dolby Digital signal. The Av2 does what it is supposed to: switches to dolby digital, but as there's only 2 channel, it plays in stereo. I prefer to manualy switch to PLII or NEO6. This 2 channel DD happens quite often with digital TV.
Emmanuel
Euphonie
