SPK Cable between Nait 2 and KEF Q35.2
Posted by: Bighead on 02 May 2002
Hello,
What's your recommendation of speaker cable to use?
Morris
Posted on: 02 May 2002 by Rico
welcome Morris. NACA5. For more details search on NACA5; first read the unofficial Naim FAQ which is full of useful information and is likely to answer all your doubts about Naim's fabulous low-cost high-quality speaker cable, amongst other things.
or save yourself some time and just order some! (remember, minimum 3.5m length per side).
Rico - SM/Mullet Audio
Posted on: 04 May 2002 by Bighead
Thank you, Rico. I'm new to NAIM and don't the best way to find NACA5 over internet(1st or 2nd Hand is not problem) Please suggest.
Also, if I want to find a NAIM CDP to partner my NAIT 2, what is the best model when considering price/performance ratio?
