storing streamed music
Posted by: Amer on 19 February 2010
Hi, sorry if this is basic, but that's the stage I'm at!
I have a uniti and macbook pro. Can I store the high quality streamed music off the uniti on the computer and if so, how?
Amer
Posted on: 19 February 2010 by garyi
By streamed music I guess you mean radio. Well you must mean that as its the only stuff coming from the uniti.
And no you cannot.
I recommend you look into itune's podcast section for lots of stuff you can download.
Posted on: 20 February 2010 by vandergraafuk
It can be done on your MBP using the VLC player. I agree with garyi that it cannot be captured from the uniti side of things. Just use your favorite search engine to find out how to.
