Wilhelm Backhaus Plays Beethoven
Posted by: Todd A on 13 August 2005
To my mind the biggest hole in my Beethoven sonata collection has been the absence of Wilhelm Backhaus. I’ve had a solitary disc of his stereo cycle for a while, and the recordings on that disc all compare very favorably to anyone. Indeed, until hearing Friedrich Gulda’s monumental Amadeo recording of the Tempest sonata, I more or less found Backhaus the best in that sonata. Clearly I had to hear what the old German master had to say, as it were, in this most august solo piano repertoire. Determined to hear his take on the 32, I then had to decide which of the two cycles, the mono cycle or the stereo cycle. Since Backhaus was already in his late 60s by the time of his mono set, I figured I should go for that one. While he certainly displays a more than adequate technique in the stereo disc I own, I figured he’d be closer to his prime in the mono recordings. So I found it and bought it and have started listening to it.
Getting things underway with the first sonata finds a curious recording. Backhaus is somewhat slow to start, and is extremely serious, with little in the way of charm. Gradually he picks up the pace, but he never shakes a slightly mannered, unsmiling sound. The Adagio is deliberate, but now a bit of feeling is infused into the playing, bringing it to life. Backhaus varies dynamics and color nicely, though he never adopts extremes, and he never sounds especially beautiful. The third movement is even more varied and buoyant and almost irresistible. The final movement starts as the first one did – a bit slow and mannered; it sounds consciously carved and not freely flowing. It’s never heavy, never ponderous, but never really nice and fiery. Yet I thoroughly enjoyed the recording.
The second sonata opens in a more jovial mood, though it’s still not free. It sounds very deliberately planned and played. The Largo is relatively fast and shows a greater degree of flexibility, but only within a well-defined range, and it displays a fine tone. All of this combines to create an insistent, march-like sound. The Scherzo is light and fast, articulate and infectious. One just sits spellbound by the playing. The concluding movement is light and varied, but it maintains an underlying seriousness. Backhaus may be smiling, but it’s a forced smile.
As I started the third sonata I thought I had Backhaus pegged: he’s deadly serious – much like Gulda – and plays within a defined, limited range, but plays as well as can be. But then he throws a curve ball. The work opens in more or less standard fashion, but then Backhaus just tears into the work, spinning off notes in a dazzling, dizzying way, just to slow way down for a bit to highlight a passage, and then returning to a high-speed, high-impact style. He plays almost recklessly fast at times. His rubato, his whole style betrays his heritage; he was born in the 1880s, after all. Why should he just stick to a specific approach? Anyway, the Adagio is generally quite fast, and is filled with subtle coloring and rubato to bring it to life. It’s not the most moving reading I’ve heard, but it is very effective. The Scherzo continues the quick playing that Backhaus adopts through the work, but despite the speed, or perhaps because of it, everything just flows together beautifully. So of course it should not be surprising to learn that the final movement is fast, but Backhaus keeps it all under control.
Okay, so now I had him pegged, I thought: he’s serious and allows himself generous leeway in tempi, though he tends to play fast. The Op 7 sonata had other things in store. The opening movement is actually played relatively slow, and while I like that, I also prefer a more relaxed sound, which this does not have. Yet I like it. A lot. Backhaus basically allows himself the flexibility to do whatever he wants, whenever he wants. His playing takes on an almost erratic feel. The Largo just reinforces this. It is a bit stiff throughout and a bit graceless in spots, and Backhaus’ tone varies a lot, too. For a while it’s lean and stripped down, then it’s richer and softer, then bright and hard. These changes can last for mere seconds or for entire passages. It all depends. The Allegro continues along this unpredictable path by being extremely well-paced and quite lovely in parts. The final movement is something of a marvel. Backhaus starts off fast and plays most of the work quickly, but he’ll slow down to savor a beautiful passage when he deems it appropriate. But he’s a bit inconsistent. You think you know when he’ll do it, but he doesn’t. After repeated listens (which I’m absolutely confident this work will get) I’ll know what to expect, but the first run through is filled with surprises.
The first of the Op 10 sonatas displays Backhaus’ traits well. The opening movement is just a tad on the slow, rich side – he certainly doesn’t rush the opener like his contemporary Schnabel – yet it all works splendidly. The piece moves along with an irresistible flow that just sounds right. The Adagio is beautiful and moving, yet even here he can’t seem to leave well enough alone. He cuts some chords short, seemingly for no reason, slightly dampening the overall effect. But fortunately not much. The final movement opens very slowly then builds up speed, and then alternates tempi through to the end. Backhaus’ delivery is different than anyone else I’ve heard, yet it all works so well I can’t offer a single serious complaint.
The second sonata again begins slowly – I think I detect a pattern – but then, out of the blue, Backhaus speeds up not a little, but a lot. He repeats this pattern a few times, and each time it sounds a bit frazzled though always under control. The second movement is quick, articulate, and possesses a serious, contemplative sound. The third movement, shorn of its repeat, sounds amazingly light and carefree. All these disjointed elements work to create a slightly off-kilter feel, but one that jells and works exceedingly well.
The final sonata of the group offers playing that almost turns the work into a miniature drama. The first movement sounds natural. Nothing is rushed, nothing is out of place; everything is free and flexible and sounds very attractive. The second movement starts in a flowing, attractive, yet serious manner, only to be transformed by some urgent, unsettled playing, changing the whole mood. Why? One wonders, but as Backhaus reverts to a more conventional take, it just seems to make sense, even though it cannot be properly described. The third movement is more upbeat and vital, though even it has some unique moments. The final movement opens with some surprisingly tender playing, then moves to a free, open sound, but then it, too, shifts again, to a more serious, contemplative sound, before shifting yet again. What is Backhaus getting at? I for one must listen again to try to figure it out. It is a remarkable recording.
So now comes the Pathetique. I figured Backhaus would go for fast, vital, and pointed approach. Nope. The piece actually opens softly, with some weaker than expected chords and slower than expected runs. But an anticipatory, subdued nervous feeling makes itself known and persists. Backhaus slowly and carefully builds up tension, but he never releases it, rather choosing to let it abate but never disappear. The cumulative effect is engrossing. One waits to hear what happens next. The second movement never really goes to slow or too deep, but rather focuses on maintaining that subdued and unreleased tension. The finale offers more of the same, and Backhaus just never lets loose like he obviously can. It’s a bit maddening, really, and Backhaus is obviously playing it a bit safe, a bit comfortable. But for the life of me, it works! Indeed, I can think of few recordings I like a lot more.
I came upon the Op 14 sonatas ready for glossed over recordings acting as a bridge to the bigger works to come. Backhaus style seems better suited to bigger, more serious works. Or so I thought. These recordings are quite possibly the greatest I’ve heard of these two works. The first sonata opens familiarly: it’s just a smidgeon slower than I usually prefer, but then turns fast, then slow, then fast again, then slow again, all seamlessly and effortlessly. It’s relaxed. It’s cheery. It’s spiffy. The second movement is just about perfect: it’s perfectly paced with perfect dynamics and perfect tone. It’s light and refreshing and amazing. The final movement is, well, it’s friggin’ perfect. Marvelous, articulate fingerwork and perfect weight (not too much) combined with a free and flexible style out of a past age all combine to make it perfect. The second sonata isn’t quite played to the same level of perfection, but it’s close. The slightly cutting sound cannot mask the marvelously light and flexible playing of the first movement. Despite a bit of brittleness, the second movement is just peachy: light, charming, and tender, it captivates with each wonderful note. To finish off the work is a plucky ‘n’ ducky and effortless final movement, with Backhaus deploying his rubato subtly and discreetly and most effectively. These two recordings offer some serious fun. Amazing.
Even in the first ten sonatas it is clear that this is Beethoven playing on an altogether higher level than most pianists ever achieve. When I consider the two excellent cycles I just finished, Lucchesini and Lipkin, they merely serve to underscore just how good Backhaus is. I said of Lipkin that even when I disagree with his choices, he still makes the piece work. With Backhaus, while some playing here and there may not sound “ideal” at first, he makes me realize that he is right and I a knave for even questioning his judgment. His Beethoven sounds right and sounds, as much as I dislike this description, natural. This is how Beethoven should sound. Finally, Friedrich Gulda has been matched. Maybe even Annie. I must hear more to know for sure.
Some quick words on sound. The recordings show their age. Some distortion and breakup can be heard in places, and some upper register notes have an unpleasant ring to them (it’s definitely the recording and not the playing), but overall the sound is more than acceptable given the age of the recordings.
