First steps in PC audio - Help !!!
Posted by: P.Bonte on 29 June 2009
Hi,
My current setup :
PC and iTunes in a separate room streaming via wifi on Airport Express to an old AV amp (PROTON) used as a DAC (24/96 capable). From there in my main system.
My target setup :
Portable PC or Mac (portable to be able to use near my main system and easely select my music), iTunes or equivalent (to be able to continue to synch with iPod and easy interface), 24/96 capability including FLAC (to start with HD digital quality, External storage (enventually via wifi) of at least 1Tb, all of that connected somehow to a DAC (toslink or coax).
Should be simple to you, but seems very complicated to me.
Thanks,
Philippe
Posted on: 29 June 2009 by Aleg
Hi Philippe
What is your question exactly, it isn't quite clear to me?
What are you looking for, a DAC?
For a new streamer + DAC combi?
The new Naim Unity?
The most simple answer would be:
Buy a Unity!
or else
Use your PC/Mac to connect an external disk to and use some software, (like foobar, VLC) to stream over a SPDIF-digital output to your DAC (make sure the DAC is capable of 96/24) and connect your DAC to your amplifier.
I'm not into the iTunes and Apple stuff, but I'm sure there is some software out there to communicate with your PC/Mac to control the software (but I heard about things like SongBook from BookshelfApps or PlugPlayer).
Aleg
Posted on: 29 June 2009 by pcstockton
My target setup :
It seems you understand it very well. You cannot play FLACs on iTunes. Try Songbird if you have a Mac. There is an iPhone app.
-p
Posted on: 29 June 2009 by Eloise
My target setup :
For the easiest solution which WILL give you high quality, I would look at a White MacBook, running iTunes and then a mini-TOSLINK to TOSLINK cable into either your existing AV Amp or ideally into a standalone DAC. For storage, I'd look at a Lacie or WD NAS drive, but if at all possible connect a ethernet cable to your laptop. If you have an iTouch or iPhone - this is an excellent day-to-day remote control for iTunes. You could use a Windows laptop as an alternative but iTunes is more tricky to setup to be bit-perfect and you will probably need to add on some form of USB to SPDIF (Optical or Co-ax) converted.
For 24/96k, use MAX to convert from FLAC to AIFF files. Alternatively for the occasional FLAC file you can use VLC, Play or Songbird.
Ideally when using 24/96k files you need to change the setting in the Audio Midi Setup utility from 16bit 44.1k to 24bit 96k AND THEN RESTART ITUNES, or many people just leave it permanently set to 24/96.
Eloise
Posted on: 29 June 2009 by P.Bonte
Hi to all of you,
Thanks for your replies, I will examine them tomorrow and eventually post complementary questions. I am really new to these questions and greatly appreciate your help.
Philippe
Posted on: 30 June 2009 by P.Bonte
Ok, so if I understand well :
I could use a portable Mac with iTunes and Songbird (for FLAC and 24/96). Thanks, I did not know this program.
Storage should ideally be wireless (Eloise why should I connect an ethernet cable ?)
If I use something like Airport express, I think I lose 24/96 capability ? Are there other alternatives to stream wireless HD FLAC ?
Philippe
Posted on: 30 June 2009 by james n
Ok -
How about a Mac mini - it can sit in your rack, handles 24/96 and can run headless so you can VNC into it when you need to do maintenance. For control use and iPod touch with the remote app. Just run iTunes. Use a program like Max to convert FLAC files into AIFF and then iTunes can play them through the standard iTunes interface.
James
Thank you all,
I will keep things simple and :
Hold on to my classic setup with airport express and itunes in 16/44.1 mode - perhaps upgrade to an iPod touch to have the remote application.
Test and play with songbird and hires 24/96 on a separate portable PC connected - with cabling -to my DAC. I will then be able to evaluate the differences.
Anyway, I do not think that a large offer of 24/96 exists.
Next upgrade could then be a new DAC, as one of you suggested.
Philippe.
Posted on: 30 June 2009 by Eloise
9 times out of 10 Wireless is fine, but remember with Wireless only one pice of data can be sent at once. For (close to) 100% reliability of the data stream to ensure no drop outs, I always find Wired is best though it's obviously less convenient. Some people will also argue that it's best to avoid WiFi as you are then introducing a lot of EM fields around your HiFi - personally I think this is very unlikely to affect sound quality in any meaningful way - I just prefer the confidence of cables over the convenience of WiFi.
Eloise
Posted on: 30 June 2009 by garyi
The songbird ipod remote is a large let down. When you select to look at music by artist it simply lists all that artists song alphabetically.
Pick for instance zappa from my library instead of then going to the albums of that artist it goes straight to thousands of songs.
Really silly and a deal breaker.
Posted on: 30 June 2009 by pcstockton
Garyi,
Is this with the free version, the paid version, or both?
thanks,
p
Thank the Lord there are so many though!
Posted on: 30 June 2009 by goldfinch
Philippe, I would also consider the PC route, although here Mac users are the mayority Windows XP and Vista are at least as good OS for music server purposes as Macs.
Besides with a PC you won't be tempted to buy the misterious Amarra player!
XP through ASIO in a decent PC can give great performance, I would expend most of the budget in the DAC.
Are you sure about that? I dont remember Mac users winning any elections Winker
Seriously though. Really? you think? I would be very surprised if this was true.
Oh well, I feel sometimes like a lost PC user among the itunes and Mac chaps, specially now Naim DAC is so ipod friendly!
Posted on: 30 June 2009 by u5227470736789439
I have iTunes working nicely on an XP based PC, using the ALAC way of storing.
Either I could go MAC or get a more external[USB] HD for the PC.
I would would like about 350 Gig of extra HD and get at least a pair of them, so I could make significant amounts of back up safety.
ATB from George
Posted on: 02 July 2009 by garyi
PCS I paid up for the full version. Have you not noticed this?
Posted on: 02 July 2009 by pcstockton
I have not. I dont use Songbird. But I suggested to a Mac friend who needs FLAC support.
