IE not displaying naim forums with security settings set "High"
Posted by: DIL on 16 December 2008
Like it says. Having raised the security setting to High (Tools=>InternetSettings=Security), I now get a blank screen when accessing the fora. The main Naim website displays OK. Anyone else experienced this?
/dl (From Firefox)
Posted on: 16 December 2008 by Adam Meredith
You just got scripts or javascript turned off. Is that a reaction to the security threat?
Make the forum a trusted site.
Posted on: 16 December 2008 by DIL
Adam, thanks for that. Naim now a trusted site in IE and problem solved.
Tried raising the security in IE to high out of curiosity as I use Firefox for the most part. And yes, that suggestion came from the current 'concerns' about IE security.
/dl
Posted on: 17 December 2008 by seagull
Only in terms of viral attacks etc. do not believe a word of what you read...
Posted on: 22 December 2008 by joe90
For your protection and security, IE has probably decided to do your thinking for you.
