NA 34 new cable
Posted by: Arye_Gur on 28 January 2001
Anybody knows the cable ?
(I have a Naim morning here...)
Arie
[This message was edited by Arie_Gur on SUNDAY 28 January 2001 at 13:20.]
We both think that it is a very good cable, I had a NA 40 which look exectly like the NA 34.
After all the electricity repair, I noticed this evening that I set the volume knob to the 9 o'clock position (not the 11) like I did with the
Mana soundframe when I used it.
There is an absolute correlation between qaulity and setting the knob, more quality - lesser volume knob setting.
(Now I wonder if I have the Mana again, maybe I'll be able to listen with the Knob on off - or furthermore - maybe it will be enough to place the cd on the Mana table and it will sing ?)
I forgot to say - I got the shimes to put under the cdi. As they look - I'm not sure Mark Tucker sent them, I'm sure he wouldn't be pleased to see some rusty shimes, I think they are not from Naim. Any way I put one in its place and the CDi is stable now , and as I said - sounds louder.
Arie
The cable look exectly as the one I use. I hope it is REALY a new cable.
Some events make me less sure with our Haifian friend.
Arie
-=> Mike Hanson <=-
That's strange.... since I got my NA 23 I've been listening with the volume at the 7 o'clock position
Sorry Arie - the temptation was too great
Sounds like you have the proverbial "piece of wire with gain"!!
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
Don't be sorry be happy. As I like to be cynical to others I'm ready that others will be cynical to me - it is okay.
Naim,
This forum only allows messages to be changed for 1440 minutes after posting.
I'm tired of this message.
Martin,
It is a new interconnect between Naim source and a Naim pre.
Arie
Don't be sorry be happy. As I like to be cynical to others I'm ready that others will be cynical to me.
Naim,
I think it is hi time you cancel this message or teach your program to count minutes.
Martin,
It is a new interconnect to connect Naim source with Naim pre.
Arie
Unfortunately, this desition is going to cost
money...
Arie
