200 vs 250 with a CD5 ?
Posted by: ricardo on 04 June 2003
Hello,
I have been thinking about upgrading my sistem for a little while now, and as i do like the sound of the CD5, my thoughts are for a pre / power amp arrangement.
Current - CD5 / Nait 5 / Flatcap 2 / Intros.
I have always felt that the improvements with a good pre amp with a power supply (almost essential) really does make a tremendous difference, and in my case would bring out the most i can get from the CD5.
So i have today been listening to a couple of alternatives to try and make up my mind. Many thanks to Audio Excellence in Bristol.
Firstly, i heard the same set up as i have (to gauge some reference) and then started with the CD5 / 282 / 200. As you can imagine (obviously) there was quite some difference to the Nait ! But, i was to some extent supprised that some of the CD's (my own) didn't show the changes as much as i thought they would. Maybe my ears ?
Then, the flatcap 2 was added in to power the 282 (and CD5). And i can only say WOW !!! This was totally different. The whole sound just lifted off, and was completely engaging, an so easy to listen to. It seemed light, airy and so detailed. There was so much on the CD's that i hadn't even heard before! It was simply fantastic.
Now although i do have a budget, having gone as for as this, i did try CD5 / 282 / Flatcap2 / 250. Now maybe the 250 is a different thing to the 200, and maybe this pre / power arrangement started to show the limitations of the CD5 - maybe a Hicap was needed, but the sound seemed to me to revert somewhat to the unpowered 282 / 200 arrangement. It sounded loud, but without the finesse and the airy quality that i thought so much of with the 282 / FC2 / 200 ! To me the openess had been lost somewhere.
Given what i have heard, i now have an instinct not to go with the 250 with the rest of my set up. Any future upgrade beyond this would probably be the CDX2, for which i still think the 200 would be an excellent power amp.
Has anyone else had similar experiences? Could it be that the source / amp balance was too unbalanced? Would a Hicap in addition to the 250 had made any difference ? I'd certaily appreciate any views on this. Many thanks
ricardo
ricardo
