Latest Uniti Models
Posted by: Tog on 25 September 2010
My loan Uniti has gone back to the dealer and my new model is now set up and working. The firmware version is version 3.0.00 ( I never noticed that it tells you its temp in this case 34 degrees no wonder my kitten likes to sleep on top of it )
The iPod connection at the rear has gone and as promised the USB port now accepts a direct digital input from a normal iPod cable - so no more expensive docking cables...great! Sound quality from the iPod is fantastic almost as good as UPnP via eyeconnect.
Network responsiveness seems much quicker but I am yet to try the N-stream app. Anyone tried it yet!
All in all a fabulous product just got better - if you are waiting for an upgrade zit is well worth it for the iPod improvements alone.
Tog
Posted on: 26 September 2010 by naimUnT
Tog
I am envious! It seems my Uniti will require to be modified (at customer's expense)! If it sounds almost as good as UPnP that is indeed good news - without the expense of the expensive cable!
