DVD5 Fan Noise
Posted by: HiDefBob on 29 August 2005
Is it just me or do others find the fan on the DVD5 a little noisy. Fortunately it does not come on too often, but when it does I can definitely hear it ... especially during quieter scenes in a movie.
Posted on: 29 August 2005 by SimonJ
Definately!!
Posted on: 29 August 2005 by niceguy235uk
never heard mine....but then.. i didnt know it had one.
Posted on: 30 August 2005 by SimonJ
I never turn mine off and also have it stacked on top of an AV2. It doesn't come on often, but when it does I can hear it. I guess it should be on it's own shelf really. Roll Eyes
Posted on: 30 August 2005 by HiDefBob
I leave mine on standby all the time. Mine is on a separate shelf.
Posted on: 31 August 2005 by SimonJ
Do you mean in standby mode when not in use? Or just left out of standby (ie not in standby mode) all the time?
Posted on: 01 September 2005 by Tam
Is it worse than my transformer hum? Winker
Posted on: 01 September 2005 by HiDefBob
I leave it in the standby mode all the time, i.e. I rarely ever turn the switch off on the back of the unit.
The fan never comes on when it is in standby. Usually it is about an hour into a movie before it comes on. It usually turns off after a few minutes. Except during quiet passages I don't hear it ... but I definitely do during those scenes. The first time it came on I thought "What is that noise!"
I don't think it has ever come on while playing a CD or DVD-A.
Posted on: 02 September 2005 by drps
Moved my DVD5 from a lower shelf to the top shelf of my mana stand and now the fan has never come on since.
Paul S
Posted on: 02 September 2005 by karyboue
I heard it once in june ... then I airconditioned the apartment Big Grin
Posted on: 06 September 2005 by HiDefBob
Since the hot summer weather has come to an end, the fan has not come on ... even during long movies like "Alexander".
