Rega Vulcan?
Posted by: bec143 on 03 February 2004
Does anyone know about this sub? It's supposedly made by REL. Is it a standard REL sub rebadges for Rega?
Bruce
Posted on: 03 February 2004 by okyknot
The Rega Vulcan is designed by REL, not made by them. It is a downward firing sub. Like REL it is very musical. I owned one for awhile, quite nice indeed.
Posted on: 04 February 2004 by gusi
I have one of these beasts. It works fine for me, I use it with Rega ELAs and a Centa.
I haven't heard any other subs so I can't compare.
I use as a sub with an AV and tried it on the ELAs to augment base. It works fine in both setups though the former is easier to setup and control.
Gus
Posted on: 04 February 2004 by domfjbrown
How does the Centa perform? I hate the looks of it, but... (I use Elas as fronts and Kytes as rears, and a Paradigm CC170 centre - it's a nice slightly muffled speaker, since most centres are fiercely overbright to me).
__________________________
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had.
