2nd speakers from AV2
Posted by: Neil Bennett on 09 July 2008
I'm moving my AV set-up into a room in our new house extension and want to drive an extra pair of (front) speakers from the AV system for outside. How is this best achieved? The system is DVD5/AV2/NAP200/175. Does the AV2 have some sort of pre-out socket (I'm away on business at the moment and can't easily check)? So connect this to another power amp? A 150? Or get a 250.2 and use the 175 for these duties perhaps?
Neil
Posted on: 09 July 2008 by james n
The 5 Pin DIN socket of Input 3 also carries stereo audio outputs. Input
3 should be used to connect the av2 to an existing Naim system.
Get a lead made up - a 90.3 off Ebay and you're sorted Big Grin
James.
