Cleaning macbook
Posted by: Alan Paterson on 30 August 2006
Can anyone recommend something for cleaning my new macbook? Screen and casing.
Posted on: 30 August 2006 by rackkit
Whatever you cleaned your last Powerbook/iBook/PC laptop with?
Posted on: 30 August 2006 by Steve Hall
I got a pack of a cleaner called iClean from the Apple shop. Comes with 2 x 45ml spray contains and a blue microfiber cloth.
A quick spray, a rub with the cloth, and my Powerbook G4 looks new again.
Smashing stuff
Smashing stuff
Posted on: 31 August 2006 by Paul Hutchings
I don't have a Macbook but I have an iMac which I guess is very similar plastic.
I've had it nearly two years and all I use on it is a damp microfiber cloth, and once in a blue moon I give the case a bit of a polish with some car polish just to get rid of any real muck.
Posted on: 31 August 2006 by Alan Paterson
This is my first laptop rackit so not too sure what to use.
Steve, does the iclean work on th screen too?
Posted on: 01 September 2006 by rackkit
From the Apple instruction manual:
Cleaning your PowerBook
"Shut down your PowerBook and remove the battery. Use a damp, soft, lint-free cloth to clean the computer's exterior. Avoid getting moisture in any openings. Do not spray liquid directly on the computer. Don't use aerosol sprays, solvents or abrasives."
Cleaning your PowerBook display
"Use a clean, soft, lint-free cloth or paper with water only and wipe the screen. Do not spray liquid directly on the screen."
Posted on: 01 September 2006 by Alan Paterson
Cheers rackit.
Posted on: 03 September 2006 by Steve Hall
quote:Steve, does the iclean work on the screen too?
Certainly does, brings it up like new.
I'd certainly concur with the comment about not spraying directly onto a PC to clean it.
The cloth that comes with iClean is a Micro Fiber one as Paul suggests.
