nordost cable identification
Posted by: minime on 04 February 2003
can anyone help i want to know the difference in appearence between blue heaven and blue angel interconnects thanks
Posted on: 04 February 2003 by quickie
I just did a search on google....Blue Heaven appears to have insulation running between the two sets of conductors,where as blue angel does not.
Paul.
Paul.
Posted on: 04 February 2003 by minime
could you tell me where this info come from so i could look for myself thanks in advance.and is there a colour difference in cables?
http://www.hometheaterhifi.com/volume_2_1/flatln.html Theres a pic of both here.This was the first hit,theres probably loads more.
Apparantly Blue angel is the only Nordost cable that doesn't use solid core conductors
already seenthat one but picture seems a bit blurred the cable i got looks like blue heaven with the blue strip down the pos side but has similar rca's as the blue angel sounds good the plot thickens thanks for your help if you find anymore info could you let me know
Has your cable got the plain piece of insulation running down the centre of it?The Angel hasn't got this.
Paul.
Paul.
the cable is din to rca it has got a insulater down the middle and is slit at rca end i think it could be a early blue heaven made up by nordost
Posted on: 05 February 2003 by minime
just spoke to nordost uk it is indeed a blue heaven as blue angel is in a distintive blue sleeve thanks once again for your help
