Do you wish to Debug?
Posted by: Don Atkinson on 10 October 2006
Incresingly I find when using the Internet (Dell Dimension XPS D266; Windows 95; IE 5.5 all about 9 years old although IE must be slightly younger) that I get po-ups with "error" messages.
For example, logging on to the Naim Forum; when changing between Hi-fi Corner and Padded Cell; and when changing from one thread to another, I get the following sequence of messages
All start with the words
A routine error has occurred
Then the various errors are
Line:3
Error: Class doesn't support Automation
or
Line: 1318
Error: Expected "j"
or Line: 1392
Error: 'Event' is undefined
or
Line: 1384
Error: Object doesn't support this property or method
If I press "NO" the pop-up disappears and the logging-on process continues
If I press "YES" I get a "Debugging" screen with loads of computer code with the cursor flashing in the offending spot (I presume)
But there is no help as to what to do!!!!!!
Similar pop-ups apprear on other web-sites but the Error messages differ.
Any advice?
Don
Line:3
or
Line: 1318
Error: Expected "j"
or Line: 1392
or
Line: 1384
Any advice?
Don
