Java
Posted by: GML on 09 December 2008
I'm running windoze xp with Firefox 3 and/or IE7 and yesterday I updated Java to Version 6 update 11.
Yes you've guessed it, Java doesn't work after the update. I've enabled all possible tick boxes and searched for solutions on Google. The orangey Java icon appears but nothing else happens.
The Java webshite simply sends you round in circles like an annoying BBC News 24 story loop. I must have seen that film (Irish Pork) of a pigs bum hole a million times.
Why didn't I just leave well alone.
Any ideas please?
George.
Any ideas please?
George.
Posted on: 09 December 2008 by Tony Lockhart
System Restore to a few days ago?
Tony
Tony
Posted on: 09 December 2008 by jon h
using your chosen disaster recovery solution, restore your system to a day before you installed this version of java
Posted on: 09 December 2008 by GML
System restore done.
Strange that some web pages from my bookmark list now decline to load and chuck me back to my desktop.
Firefox has decided that it wants to close rather than load these pages.
The trouble is Jon I removed the three older Java versions in a moment of sheer madness. I feel a 're-format the hard drive' headache coming on. Bugger - those imacs look nice.
The console is showing this error message.
Java Plug-in 1.6.0_11
Using JRE version 1.6.0_11 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\George
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
load: class DJClock.class not found.
java.lang.ClassNotFoundException: DJClock.class
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketException: Permission denied: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: DJClock.class
load: class imageviewer.class not found.
java.lang.ClassNotFoundException: imageviewer.class
... 7 more
Exception: java.lang.ClassNotFoundException: imageviewer.class
... 7 more
Posted on: 09 December 2008 by icogs
It's not your Java runtime installation which is at fault, it is the DJClock applet. I just went to the DJClock website and got the same error, and my Java installation works fine.
