Please help me to find parts for a Goldring Lenko GL75 deck
Posted by: Alex S. on 29 January 2002
Thanks,
Alex
I had a quick Google trawl and came up with....
Technical & General
PO Box 53
Crowborough
east Sussex
TN6 2BY
Tel: 01892 654 534
It seems that they are able to supply any parts needed,manuals and "How to do" info,but they do not service themselfs
Hope this helps
chris
Thanks,
Alex
Technical and General are good, I bought parts for mine there many years ago.
Tony.
Tery Sullivan of Garrard fame uses these as a basis of a record cleaning machine, and may be able to help.
Peter
Alex
PS I may nick it and turn it into a cleaning machine. ![]()
Tonearm bearings and drive wheel to be ordered shortly.
The arm bearings will have you in hysterics - the vertical bearing is a knife edge which sits in a rubber V. It is the rubber part that you replace. Don't assume that the forward and backwards play in the arm is abnormal, its part of the design! I remember ordering the bearings for mine, and then realising that the ones in there were actually to spec. I never bothered fitting them. IIRC there are two slightly different designs of idler wheel, one with a circlip, and another with a threaded fitting… might be worth checking.
I bet the Lenco would actually sound great in a big heavy plinth with a decent arm and cart, the build quality is truly excellent, its just that the arm is completely insane. They were often fitted with SME 3009s as an alternate.
Tony.
