CDS1 Owners
Posted by: ray dodd on 24 September 2001
Can some kind CDS1 owner confirm the position and number of the transit locks.I have located the two allen screws in the loading tray .Are there anymore that I have forgotten ?
Ray
Total of two screws in the loading tray area as you've found. There are three additional screws on the bottom of the unit. They lock the mainboard's suspension during transport. Remember to lock the upper (transport or loading tray) just as you've done "before" flipping the unit over.
When re-installing the cds after transport unlock the "lower" (mainboard) screws *first* , flip the unit right side up and unlock the "upper" (transport or loading tray) screws *last*.
hope this helps,
dave
Thanks for that,I can now send it to naim for upgrade to a CDS2.......I presume the transit locks are different on the CDS2.
Ray
I don't think it matters (side vs. upside down) when it comes to the lower screws on the cds. The cdi doesn't have a suspended mainboard , simply rubber grommets between board and support pillar nuts (not 100% sure on this though). I believe the transit locks on the cds 2 are the same as the cds1 , good question for your dealer when you pick the unit up.(or Naim.... or just thought of this... check the cds2 owner's manual on-line !)
Congrats on the conversion btw. Waiting for mine to break first ![]()
regards,
dave
Alex.
Team
Sounds good to me.
regards,
dave
