Aromatic
Posted by: Arthur Bye on 29 September 2001
Arthur Bye
Robert Ritchie of Robert Ritchie HiFi in Montrose, Scotland, I believe has one in a box (well, he did last time I looked - 2 mth ago). His number is 44 1674-673765. As to whether it works, he does a little 'mod' to it to make it work as intended, but his normal advice is not to have it fitted.
regards
Dev
Now featuring a Linn LP12/Lingo/Aro for your listening pleasure.
The Aromatic works just fine. I have no problem with mine at all and as far as I can tell, it makes no difference to the sound. They're hard to get nowdays but if you have no luck with Dev's suggestion just try ringing round all the dealers, there's bound to be a few getting covered with cobwebs. £100 is the going rate incidentally.
Dev - any details on the 'mod' - mine seems to work as nature intended without modification.
Now does anyone know where I can get an autochanger for my LP12???
Steve
Train the wife - it can work!
Don
You'd also need to drill out the armboard, or order another pre-drilled armboard--and this assumes that your LP12 plinth is not ancient (i.e., needs corner braces of a reasonable size.
Dave Dever, NANA
Steve
You have no idea how scary that concept is...
Steve
Not quite - it's made from left over bicycle parts. It works on the same principe as cable operated brakes. The lever is at the front RH side of the deck between armboard and plinth and connected to the lifting mechanism which pushes up through the armboard to lift. Pic attached - sorry about my lack of photographic skills. I used to be quite good until I did a photograpy course and I haven't taken a decent picture since.
Steve
Sounds like I can get one from Naim, so I'll give that a shot first.
Dave Dever:
Since I've given up drinking and smoking(and puking and coughing) my hands aren't as steady as they used to be. I know that one of these days I'm going to croak a boron cantilever. Hence the desire for an Aromatic.
Kan Man:
Thanks for the photo. I can barely make out the Aromatic, but I get the idea.
I've just bought a Lyra Helikon SL and they give dire warnings against using it without a fully damped cueing lever, voiding the warranty and other nasty stuff. The Aro is pretty decent at cueing unless you want to play a track in the middle of the LP. Then things get shaky.
Arthur Bye
Since I've given up drinking and smoking (and puking and coughing), my hands aren't as steady as they used to be
Funny, If you've seen the way people cue up vinyl at hi-fi shows with $4000 + expensive cartridges, you'd issue that warning, too. (I'd have kept the occasional drink--fewer inhibitions about stylus damage--as the cantilever better be able to handle it.)
Dave Dever, NANA
P.S. I'll check tomorrow--I believe we've got a few hidden in the back of the stockroom...!
cheers
dev
