Anyone Tried KEF RDM-2 with Naim???
Posted by: king on 01 December 2003
I've been offered a used pair of KEF RDM-2 recently and wondered if they go generally well with Naim.
Based on the good track record of KEF's drivers, I have quite a good feel about this match for now, unless some folks here have a different opinion.
Hope to hear some comments here soon.
Thanks.
King
Posted on: 01 December 2003 by Stephen Dupuis
K,
The Kef RDM2 is a great little speaker. The RDM2 is a front ported design and work resonable well close to walls (30 cm or so) with 90 dB/w. The bass is limited to say 70 Hz or so, but everyting else just swings. If the price is right grab them but if you have a bigger room you might look for a sub to add a little weight. The drivers are actually a step up from the reference series from the 1990's as the RDM series used cast aluminum baskets (the ref used steel).
Steve
Posted on: 01 December 2003 by king
Hmmmmm............
Thanks guys for your comments. I think I'll give it a try.
I looked at the specs and know that this pair will not deliver deep base, but now I'm thinking that if you want deep base, sub is the way to go........
King
