DIY questions for a faik Fraim replica...
Posted by: johno on 26 March 2002
I only saw the Fraim on Saturday in a French HiFidelity magazine.. and thought wow! Then noticed the price! Ouch!
Unfortunately I want the Fraim sound/look but not the £1000+ cost needed for all my Naims.
I did read a post last night on the Fraims and someone was discussing the ball bearing placement and contact patches... as they are DIYing too.
The main shelves I intend to make out of 25mm MDF and get these CNCed out in a similar way to the Fraim.. I may intend to machine under them to lighten the shelf without reducing the stiffness (ie leave ribbing etc... like Mission do in the 780 series speakers internally)
Question: Anyone know what the flexural modulus of MDF is?
I have 3x1m lengths of 18mm diameter stainless steel studding... purchased a couple of years ago to make a TNT flexi-shelf unit... this never materialised and I bought a bolt together SO table instead wobbly/bad.
The Ball bearing isolation part was a head scratcher... last night I had a spark of genius and will use one small pilot hole for a jig and make 3 larger holes 120 degree cut to sit 3 ball bearings in.. then glue these in... then place 'the ball' on the 3 point contacts created by the balls... to get the same effect as 'The Socket' (or better microscopically!)
The only thing I am not yet fully decided on is the 'leg' around the 18mm stud.... whether to use a block of hard wood or some sort of open metal frame as Naim... I may use a nice light hardwood to match my Beech SBL's and use 3 small ball bearings (1mm) again 120 degree spaced to make it a very rigid leg with the shelf above (gap less than 1 mm when clamped). The wood will also allow a hole underneath to cover the nuts of the shelf below. I will have to use nuts instead of 'cups'. My cup will have to be machined out of the top of the 18mm studs.
Does the cone sit in the cup on it's point? ie cup is flat or on a small hole in the cup?
Is glass thickness critical as 6mm toughened glass is standard size but >6mm TG is hard to get... may start off with my SO glass unfortunately this is 4mm.
I know this could possibly not sound as good as the Fraim but at a Fraction of the cost.. this can go towards my second silver-edged NAP250.
The nuts for the 18mm stud are 30mm AF ! and the washers are 47mm! If nothing else it will be heavier! ;-)
john
