DVD5- does it make sense
Posted by: bbb111 on 08 September 2006
I know the issue has been raised before but I wonder if anyone has new thoughts. I'm seriously contemplating to purchase a DVD5 come bonus time to replace my 2 year old Arcam DV78. I love my Arcam unit. For its price you get pretty good CD playback and very good picture. Does it make sense to even think about the DVD5 or should I stick with my Arcam? I am listening 95% of the time to Vinyl but watch about 3-4 movies/week.
Posted on: 11 September 2006 by HRC99
I moved from a DV79 to a DVD5 and it was worth every penny to me. I bought it second hand so that made it a little less painful financially. But if you can afford it, I'd highly recommend it.
There was not a massive difference in the picture quality but the difference in sound quality was immense. It's a wonderful DVD player!
Posted on: 11 September 2006 by scottyhammer
is the dvd5 multi region or is there a chip upgrade ?
regards, scotty
It can be multiregion if you use a hack that I don't think is allowed to be put up on the forum. It is easily found though.
Posted on: 11 September 2006 by Former member
I Think if you were to ask Naim or your dealer if there is a code they will give it to you i got one for my N-vi. regards munch
or have a look on a well-known av forum!
