Simple Flatcap questions
Posted by: Stephen Bennett on 18 May 2001
The Flatcap can power 2 components, right? Could it power both a CD5 and 32.5 pre?
Stephen Bennett. Composer and sound design. (UK)
http://chaosstudios.gen-next.com
henry fool http://www.collective.co.uk/henryfool The Fire Thieves: http://tft.gen-next.com
Author of 'The Fast Guide To Logic' http://www.pc-pubs.demon.co.uk/fgel.htm
and 'Making Music with E-Magic Logic Audio http://www.pc-pubs.demon.co.uk/mmela.htm'
Posted on: 18 May 2001 by mr saucisson
Flatcap2 can(although the supplies are not of the same quality). Flatcap the original cannot do so.
Ben
Posted on: 18 May 2001 by Mike Hanson
As Ben said, only the Flat-Cap2 can do what you need. You use the primary supply on the 32.5, and the secondary on the CD5.
-=> Mike Hanson <=-
Posted on: 18 May 2001 by Steve Crouch
A friend has Flat Cap2 with Nait5 & a CD5. I have lent him an original Flat Cap to power the CD5 so as to leave the FC2 to power only the Nait5. Is this the best option?
Steve
The Flat-Cap2 is better than the older Flat-Cap. If you have a CD5 or CD3.5 and a Naim pre-amp, the better supply should go on the pre-amp.
-=> Mike Hanson <=-
If you have two supplies, then put the better one on the pre-amp. If you have only one, then try the CD then the pre-amp, and decide which you like better. Each configuration provides different benefits.
-=> Mike Hanson <=-
