Another Dynavector death
Posted by: Chris Metcalfe on 06 November 2001
I guess I have two options (and then another subset of options), i.e. take it in for a repair, or phone my wonderful insurers and get enough reparation to pave the way for a possible new turntable scenario (e.g. a less fragile new-P9 with its purpose-designed cartridge). Although I've always enjoyed the LP12, particularly since installing the Armageddon, I'm increasingly finding its finicky nature (or that of this particular combination) a nuisance.
All of your opinions would be etc.
[This message was edited by Chris Metcalfe on TUESDAY 06 November 2001 at 17:27.]
So thats 2 XX1Ls (you and Vuk), a MC 10 Supreme (me), A £1k Lyra (Joel)... Go on who else has done it?
Tony.
Sorry for your loss.
Your dealer will be able to help you get a replacement value note to your insurer. They usually pay up. The straight replacement would be the XX2, which improves significantly on the XX-1L.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
the Aro decided to deposit it in such a way that the stylus no longer seems to be attached to the cantilever - it skated across an old Teardrop Explodes LP on a wad of fluff.
Let's hope it was Kilimanjaro, to make it worthwhile...
Dave Dever, NANA
Yeah, and the first pressing with the band picture, not the re-issue...
Tony.
It was 'Wilder', actually - probably 'Bent out of Shape' or 'Falling Down Around Me' (!). What happened was that the Aro slipped from my tiny delicate fingers as I was lifting it at the end of side, and then dropped and skated (with its accumulated fluff) over the entire record, leaving the stylus somewhere... I haven't had the heart to investigate this morning.
I do have the original 'Kilimanjaro' though, but without 'Reward' on it I probably prefer 'Wilder' (take another listen David).
Frank,
I'll be in touch re the replacemement. I was serious though when I mentioned that I may try and replace the whole lot, as I've found that it's a tricky deck to deal with a lot of the time - big but delicate cartridge on a loose arm over a fussy suspended turntable. Power supply's the easy bit!
I know exactly what you mean. The three "big league" turntables I have owned are the Xerxes / RB300, LP12 / Ittok, and currently the P9 / RB900. With both the Xerxes and the P9 it was possible if necessary to cue them accurately when totally pissed. The Aro would scare me to death when completely sober. Naim analogue stuff does admittedly sound great, but the functionality and ergonomics are utter crap (no 45rpm, no cueing lever).
Buy a cartridge, you obviously need one right now, then wait a bit and check out the forthcoming P9 replacement. I would attempt to stick your LP12 up against the new Rega, a Nottingham Analogue, and a Xerxes 10. All are simple to use, offer both speeds, and (assuming the new P9 ain't a ringer) sound great.
Tony.
The chaps at Rega now don't think there'll be a matching M/C cartridge immediately, though the deck is due out fairly soon and the improvements to the arm look especially interesting. Another reason for going for a non-suspended deck would be that I could once again use my wonderful (and brilliantly named) Audio-Technica safety raiser, bought in 1981. They don't work on LP12s.
I'm dubious about buying another Dynavector if I keep the LP12/Aro, as its size causes the arm to foul up if the lid is down - another irritation. I'm almost tempted to go for an Ekos/Arkiv with the LP12/Armageddon - but that sounds pretty like Ross Blackman....
I admire both your patience and particularly your eyesight! Bet you've got one of those big Anglepoise magnifier lamp things...
BTW, what was the deal with the black Ittok? For some reason I've always assumed that they were all LVIIIs, but yours looks to be an LVII (armrest post) Do you know the details?
Best;
Mark
(an imperfect
forum environment is
better than none)
Lord knows how you got one onto the LP12!
No lid!
I saw and heard one at the Festival of Sound and Vision in the Sheraton Hotel in Edinburgh in the mid/late eighties, fitted to an LP12 with the original Armageddon conversion (which I believe never made it to full "product" status), which involved, I think, a new bearing, new power supply, and hi-cap powering 323/322 type phono boards installed in the LP12 plinth.
It sounded fantastic, but was, infortunately, shortlived - almost stillborn
Chris L
The reason I ssked is that whenever these appear for sale they seem to command enormous prices for LVIIs (compared with standard Ittok). Obviously one can understand the LVIII being worth a bit more, but I just wondered if there was anything different about the black ones apart from the colour...?
And yes, that looks like an exception bit of timber (your plinth).
Best;
Mark
(an imperfect
better than none)
The problem AFAICT is that the ARO armlift is so tall that any cartridge bigger than a certain height will cause it to touch the LP12 lid when down.
Query - is the XX2 more manageable in terms of size? Did the XX1-L cause the same problems on a P9 (I seem to remember spacers being involved).
Obviously if I'm going to stick with the LP12/Aro it would help to get a cartridge which didn't cause this problem. Similarly, if I decide to changhe to the new P9, I wouldn't want to go mucking about with spacers, since one of the attractions of the P9 is its 'straight-from-the-box', anti-tweaking nature.
Originally posted by Rob Holt:
Mark,The silver and black Ittok are mechanically identical.
Rob.
That's what I would have thought. However, there's one on eBay currently at 415 quid, which sounds berserk to me. I must admit I once thought the black ones were built in Glasgow, rather than Japan, but I've never seen any confirmation of this.
Best;
Mark
(an imperfect
better than none)
You'll may find that the Black Ittock's (the 12" ones) were made in Glasgow, but the normal Ittocks that had the optional black finish were made in Japan, along with the normal items.
BTW, the one on ebay is just a "normal" Ittock with the optional black finish, so I don't think it's worth the current price!
Chris L
P.S. Hey, 100 posts, must celebrate ![]()
