Using NaimUniti with iTunes
Posted by: arasekhi on 04 March 2010
Hi Folks,
I'm a newbie to Naim and this forum. I just purchased a NaimUniti and I'm trying to achieve the following:
- Import CDs into iTunes in a format that is high quality and that will play on the NaimUniti. I tried WAV but the usability is not good since there is no metadata and navigating to find the songs on the NaimUniti is difficult. I wanted to try Apple Lossless, but read that NaimUniti does not play this format when using UPnP.
Basically, I am looking for a way to play a lossless format that iTunes supports on the NaimUniti via UPnP that also embeds metadata (artist, genre, etc.) so I can easily navigate through my music collection.
Any suggestions would be much appreciated.
Posted on: 04 March 2010 by 0rangutan
iTunes on Mac or Windows?
Posted on: 05 March 2010 by Eloise
If you're happy for your Mac to be running, then use the EyeConnect UPnP server which should transcode AIFF or ALAC files into the WAV format which is compatible with the NaimUnity. There are other UPnP servers which also support transcoding - there is a comparison chart here -- http://www.rbgrn.net/content/2...ws-mac-os-x-or-linux -- which may be of help.
Eloise
Posted on: 05 March 2010 by garyi
XBMC is free and happily acts as a UPNP server sending flac etc to the Uniti.
IN my experience Twonky is shite, eye connect is expensive and unresponsive constantly requiring restarts and ALS is limited.
Posted on: 05 March 2010 by arasekhi
Mac
Eloise
Thank you for your help. I'm actually already storing all my iTunes music on a NAS drive which is UPnP capable. I did this mostly to avoid having the computer on all the time. The same disk is also being accessed by a separate Sonos system.
Thanks much! I'll look into it.
Posted on: 05 March 2010 by David Dever
EyeConnect is free (no need to purchase if all you need is audio) and easy.
