AV2 factory reset
Posted by: DellboyOne on 03 June 2008
My hard working AV2 has had a senior moment and I cannot locate my user manual so I'd appreciate it if someone could tell me how to reset the unit to the factory settings.
I've also lost the Multi output function.
Many thanks
Posted on: 03 June 2008 by tonym
To restore the factory defaults, go into the setup page (Input setup mode, press & hold the Input button on the front panel, speaker setup mode, press & hold the mute button) then in each mode press & hold the handset display button. (display flashes once to confirm)
Posted on: 03 June 2008 by Adrian F.
Why don't you download one?
http://www.naim-audio.com/products/intro_manuals.html
happy resetting
Adrian
Posted on: 03 June 2008 by DellboyOne
Many thanks guys. Smile
