cheap tweek
Posted by: Mike Cole on 03 April 2001
http://www.tnt-audio.com/clinica/sblocks1e.html
Mike
Have you tried glass in place of the top piece of MDF? If so, does this give similar benefits to the foot corn blocks (the most attractive name I could come up with)? A friend of mine has a Nait 3 and CD3.5 that he has been wrestling with. He is using glass now in conjunction with stone slabs. His system presents a mix of flat and round earth virtues set up this way.
- GregB
Insert Witty Signature Line Here
I have tried a glass/blutak sandwich before. It made the sound leaner and brighter. I ended up taking it out after about a week. After a couple of days of listening, I think this tweak will stay put, it opens up the sound almost the way mana did with my LP12. I may try my CD3.5 next to see if it is affected the same way.
Mike
Matthew
I was wondering if you tried glass as the top shelf of your DIY support, so that the player sits on the glass rather than MDF. The glass/blutak thing went on top of the player, yes?
- GregB
Perfectly happy with the results (but all used in my secondary system)
I was planning on doing that originally, but the cost of a 4ft by 2ft sheet of glass with 6 holes drilled into it was about $400 - that is not quite a DIY type of price :-) I have tried the glass/blutak on top, on bottom and on bottom supported by spikes. The best sounding solution so far has been to put the player on 3 cones (points up) supported by the 3 layer ball/nutter thingamajig. I will try the cornblocks next and if that does not work I will (at some point) invest in another Mana wall shelf. After the few days that I have had the cornblocks under the Nait, I still like it quite a bit. (of course my wife just rolled her eyes again)
I had 6 mm glass cut into roughly 20" x 17" (or therabouts - measure first so that it fits all your components) for $13 per piece. I later found a place that would provide 10 mm for $15 a piece. Call a few local glass shops and see what they will do for you.
- GregB
I also made a lead for my then 140. Can't really recall the effects on that as I now have a 250 and continue to use the lead. Maybe sometime I should go back to the orginal leads provided to hear what happens.
I do feel it becomes a case of what you are used to after a while. I've listened to other systems, but they always seem to come across as clouded compared to mine, I know it isn't the system it's my mind!
