Is music streamed to NDX passed to Naim de-jitter buffers?
Posted by: Razor on 08 December 2010
The NDX white paper is in parts copied and pasted from the HDX and nDAC white papers and has not been properly reviewed as one or two items copied have not been changed for the NDX. For example, one section says "well below the noise floor of the DAC chips" but there is only one DAC chip in the NDX.
An early paragraph in the paper says "So the ripping engine developed as part of Naim’s HDX hard disk player became the first building block of the NDX." But the NDX does not do ripping!
Some of the Analogue Output Filter section is copied word-for-word from the HDX white paper but with just a change of op-amp type; this is puzzling as the same words are used to justify the choice of different op-amps.
Because of these weaknesses I find it hard to draw definitive conclusions from this paper. However, it is clear from the NDX's white paper that data arriving over SP/DIF is passed to the NDX's de-jitter buffers:
"When the NDX is playing audio via S/PDIF, the source of the S/PDIF signal is the master and the NDX’s master clock must, on average, match the frequency of the source clock. ..."
However, it is not explicity stated that data arriving through the NDX's streaming module goes through the same de-jittering. Now it may well be the case that there is less jitter generated by the streamer than by SP/DIF, but even so it would make sense to use the de-jittering as for SPDIF. It is true that the schematic suggests that this is the case, but schematics are of necessity approximations.
Can someone please tell me whether or not data streamed to the NDX, as distinct from passed through SP/DIF, goes through the de-jittering process just like SP/DIF data does?
