240 Replacement?
Posted by: u5227470736789439 on 05 February 2006
I have a 1989 registered Volvo 240, which is rust-free, and runs like a sewing machine. It has broken down once in six years. Splendid, and it is a safe car, which has so much passive strength that it will be hard to get an equally fine replacement.
It still does about 40 mpg, and when I last took it on a holiday to Norway the old bird averaged 43.2 mpg over nearly 3000 miles, but she is a bit of a lump tp park, and I would prefer 60 plus mpg. I bought it (as a replacement for another even older one of the same model) as it is one of the few saloons, long enough inside to get a double bass into, and transport it with minimal risk in the event of an accident. I no longer cart a double bass about.
I was thinking of looking at a Peugeot 206 with 1.4 HDMI diesel, as this is a very economical engine, and pulls nicely. Naturally I am not after high speed or particularly quick acceleration, but would enjoy the flexibility and high torque characteristic of a diesel. The Volvo engine is itself very torquey, and rather diesel-like in its almost lorry engine-like characteristics, so I don't want a buzz box.
Any thoughts gratefully received. Fredrik
Posted on: 05 February 2006 by Mick P
Fredrik
Stay with the Volvo and buy some DBL's with the money you have saved.
Mick
Posted on: 05 February 2006 by u5227470736789439
Dear Mick,
I was thinking of a second hand one, and very much if the Volvo breaks big time really. No, I have my priorities sorted on the DBL front. And they will last even longer than a Volvo too!
All the best from Fredrik
PS: Did you ever go up to Rodborough and try the DBLs out? If you did you will have seen the very ones I want to get when the time comes later in the year! You should give yourself that treat. I know I came away knowing that they worked very nicely indeed on a 200, but a 300 was even nicer. In fact, it was nigh a miraculous effect!
Posted on: 05 February 2006 by BigH47
The Puegeot will feel like it's made of cooking foil and plastic cups against the Volvo. How about an S40 Volvo new or s/h you will still keep the safety aspects and good comfort. Diesel options are available I believe. I wouldn't bank on the Peugeot only breaking down once in 6 years.
Howard
Dear Howard,
I definately cannot justify another Volvo, however nice that might be. I think it will be something very light and definately second hand. Maybe I should be prepared to keep the old tank going for a bit longer yet. It is not depreciating any more, and the servicing is simple and not expensive. It's just I think that I could be greener on the fuel front!
Fredrik
Posted on: 05 February 2006 by Steve Bull
Originally posted by Fredrik_Fiske:
Dear Howard,
Fredrik
You may save some money on fuel with a new(er) car, but put it into perspective and price up the depreciation and servicing costs that will come hand-in-hand: you may be better off sticking with what you have if you know it's reliable and not going to fall apart on you.
Steve.
Dear Steve,
You are right. Nothing will runs for so little as the old car. Times I have threatened the old bird will the crusher, in spite of rather liking her.
That is the good thing about this place. Roughly huen ideas get refined! In fact I ought to bite the bullet and get the cam belt changed, and live with her till something big fails, which might be a long way off on past experience.
Posted on: 06 February 2006 by Markus S
I'd also keep the Volvo. If you want to go Green, think about converting it to Natural Gas.
Posted on: 06 February 2006 by hungryhalibut
Fredrik
My wife has a VW Polo 1.4TDI. It's a great car, solid, comfortable, nippy and does over 60mpg. Much more credible than a Peugeot 206.
Nigel
Posted on: 06 February 2006 by DAVOhorn
Dear All,
Why this obsession with mpg.
Unless you do over 15k per year it is a no brainer.
Also run an old heap as it is only burning fuel.
A new car has used much more energy in its manufacture than an old heap does in its running.
My heap cost £1000.00 3 years ago and on a run to huntingdon last week did 28 mpg not bad for a Sierra XR4x4 2.9I with 105k on the clock and being of 1989 vintage.
So stay with the old girl for a little longer.
If you have to hit something a Volvo is pretty good, a Pug is a much more light weight affair and probably not as good a bet as the volvo in a shunt.
Years ago Russ Andrews had a major shunt in a Volvo Estate. The car was a real mess seriously destroyed. But he got out with only minor injuries. When i saw the photos of the car it was a real testament to the strength and design of the car that it could be that damaged and yet the driver walked away with barely a scratch.
The police said any other car and it would have been curtains.
If a car starts and more importantly STOPS then run it until is does one of the above.
regards David
Posted on: 06 February 2006 by u5227470736789439
The old girl is called Henrietta (or just once Jezebel!), and I have decoded to run her to her end.
Fredrik
Posted on: 06 February 2006 by Rico
Yep, certainly sounds like there's nothing wrong with it, so why not keep on fettling it and enjoying low-cost green milage! The cost difference between your 240 and any replacement vehicle will certainly pay for a good deal of fuel in the 240's tank.
Posted on: 07 February 2006 by Clay Bingham
Fredrik
Even on this side of the pond, where we are not noted for our "greeness" nor for keeping older cars running, a Volvo 240 is regarded as a classic. They just don't build em like that anymore! I have a friend who lost his to an accident. He still misses it ten years on.
Clay
Posted on: 07 February 2006 by Guido Fawkes
Fredrik
Mrs Rotf had a Peugeot 307 with diesel engine - it was very nice when it went, but it broke down quite a few times - once losing all its oil on the M4. She now has an Audi A3 and it seems to run and run. Likewise I have an old Honda that seems to run and run. If your Volvo is reliable then I'd keep it.
Rotf
