recommendation for centre speaker
Posted by: funtastick on 07 June 2010
hi bros, any center speaker to recommend for neat momentum 3i? thanks
Posted on: 07 June 2010 by funtastick
which would be better? neat motive c or neat centrum? thanks
Posted on: 07 June 2010 by SC
You could try getting in touch with Bob at Neat, either through your dealer or better still directly email him (he's very good in replying) and see what he advises would be a good match...? He may even be able/willing to make something custom for you (if you were prepared to pay) or sell you a single 3i for centre speaker use...
Failing that, I am sure the other Neat centre speakers would be a suitable tonal match - perhaps keep your eyes out for a Ultimatum MFC, which would be a step up from your Momentum fronts, or the Motive C would be a much cheaper option....I guess it really depends on how important your multi-channel use is going to be....?
Steve.
ok thanks for your advice SC, appreciate it Smile
