CD Cleaning
Posted by: Naheed on 20 June 2002
Whats the recommended method.
Currently i use Eco3 for the label side, and a standard lens cleaner on the play side (i breathe on the cd then wipe away the residue) confused
naheed...
Posted on: 20 June 2002 by J.N.
in the past and it can cause minor surface scratching.
I now just wipe off any visible dusty stuff with a spectacle cleaning cloth.
For the occasional bit of stuck on gunge, I use a disposable pre-moistened spectacle wipe from centre to edge.
