BBC's Listen Again....interrupted
Posted by: Christopher_M on 07 August 2008
Dear All,
I thought I would ask you guys first rather than make a more painful approach to possibly the BBC and/or BT. The last couple of times I've used the Listen Again feature, my BT homehub has gone down. All the green lights go out, then they gradually come back over a three minute period. Then I select and load up the programme again, find the point where I last left it, and then I get maybe another five minutes or so until it collapses again.
The MacBook is placed on top of the CD5 throughout and this setup has worked perfectly for me in the past. As you can see, I'm completely non-techy, but if this has happened to any of you please let me know how you solved it. It's really spoiling my enjoyment of the Listen Again facility for radio. Thanks!
Regards, Chris
Regards, Chris
