Torque the DBLs screws........
Posted by: Onthlam on 23 August 2003
Can anyone offer the best wrench to buy at Home Depot?
What are the torque settings for the Drivers in the DBLS?
Has anyone put on paper "how to" optimize the suspension for the tweeters?
Thank you,
Marc
Posted on: 23 August 2003 by Derek Wright
Marc - check your PTs
Derek
<<Have you checked your PTs today>>
Posted on: 23 August 2003 by Onthlam
Derek,
What/where do I find these PTs?
Thanks,
Marc
She asked for a Grand piano.
All I could give her was an upright organ...
Posted on: 23 August 2003 by Arthur Bye
Mark:
This is the wrench I got with my NBLs which has the same tweet and mid.
Can't find my manual for the setting either.
I think RS is a brand from the UK.
Just get a Sears Craftsman torque driver. I'm sure it will suffice. Just make sure you get the kind that "clicks". They are more accurate than the twisting bar type.
Arthur Bye
Arthur,
Did I understand that yours came with the NBLs?
Thanks for taking the time..The picture helps...
I will pick up a wrench that clicks...
Are the allen screws metric?
Marc
Still need the nums.......
Posted on: 23 August 2003 by Martin M
4mm metric. And 3.8 Nm of torque on the bass and mid. The correct torque wrench was $55 in Home Depot as I recall.
Dressing the tweeter cables was the most important aspect of getting a nice bounce out of my DBL tweeters - and not doing the screws up too tight.
Martin,
Thank you...
Would it be possible for you to take a picture of the tweeter cables? (In proper dress...)
To my understanding there is some tweaking of the metal bits that are in view at the front of the tweeter...
Could you also describe the steps to make this process/project as easy as possible???
I wish there was something like this in the manual.
Went to the Naim site..There was no manual for the DBLs to be found.......
I'm off to Home Depot....
Marc
Posted on: 23 August 2003 by Ade Archer
The SBL bass driver bolts are supposed to be torqued to 3.6nm. The 'light-duty' of my 2 automotive torque wrenches starts at 10nm! When I enquired I could not find one that would go as low as 3.6nm. Any ideas where you would get a torque wrench that went so low? And how critical to performance is it having the bolts tightened to 3.6nm
Ade
Marc:
The person that I bought my NBLs from said that he got Chris K from NANA to get him one. The box that it came in has "NANA" markered on the top. I'm guessing here but he probably did a good job of begging.
The 3.6 Newton/meters sounds about right. It's just a touch more tight that hand tight, but tighter than "Linn tight".
Martin is correct about it making a difference too. It's actually a little disconcerting that it makes as much difference as it does.
Arthur Bye
Posted on: 23 August 2003 by dave simpson
"The 3.6 Newton/meters sounds about right. It's just a touch more tight that hand tight, but tighter than "Linn tight"."
Shouldn't that read "lighter than Linn tight" Arthur(?)
regards,
dave
Marc - goto "My Space" - Private Topics
Derek
Posted on: 23 August 2003 by Tarquin Maynard - Portly
Derek
Derek
Assuming you are telling Marc what he needs to know, would this not be worth publishing for mere mortals?
Mike
On the Yellow Brick Road and happy
Arthur:
Went to Home Depot. Nothing.
Called Oshe..Nothing
Called Sears. Confused.
Went to sears.. Located booty....
Martin:
The lowest I could find was one with the ability go as low as 3.61...I ended up torqueing to 3.72....That was as close to 3.80 I could get on the wrench.
When I hit the magic spot, it was very subtle. The wrench just gave a bit. No click...
The tweeters I am not going to touch until someone can walk me through it..........
Every one of them were loose. Some were a matter of a quarter turn or less. There were a few that were closer to a full half turn.........
The verdict:
Made a big difference. Cleaned it almost to much. Much tighter all around.
Thank you all. My quest for torqueing for the first time has been completed.
I need to turn over now, I'm tired........
We'll cuddle in the morning--I promise.. Big Grin
Best Regards,
Marc
Mike,
Derek was giving me information on something completely off topic....
Something that I asked per another thread...
Thanks,
Marc
"The tweeters I am not going to touch until someone can walk me through it.........."
Marc,
Email Chris K. about the procedure...he routinely does this on DBL installs.
hth,
dave
Dave,
Thanks...
I had asked him about this in person.
He said it was easy...
If I were to feel good and confident with the end result? I would need to bench marc another DBL setup.. To see how the dress of the cables are. To see what the bounce feels and looks like. Most important, how it should sound...
I will contact him to see what we can do to make this happen..
Thanks..
Marc
I stand corrected.
"Linn Tight" has always meant to me:
"tighter than a nun's bun on Good Friday"
At least that's how it was explained to me on my first LP12 setup demo. It made it easier to remember that way.
I don't think that 3.6 n/m is that tight.
Arthur Bye
LOL ;-)
"I don't think that 3.6 n/m is that tight."
Sounds like it (and quite different from DMS B-110s/B-139s which love to be torqued ;-)
regards,
dave
Posted on: 24 August 2003 by jcc
Here's a couple of links for torque screwdrivers.
Snap-On
Craftsman
Martin M,
Any info on the $55 Home Depot wrench?
regards,
jim
Posted on: 24 August 2003 by Martin M
It's called a Husky 39102.
Er eventually, but I don't possess a digital camera and tweaking those tweeters up is a pain, so I'll send you the pics when I do it. I guess Chris can run you through it though.
Thanks Martin!
Posted on: 24 August 2003 by Arthur Bye
The Sears driver seems a bit pricey at $149
Sears torque driver
Mouser and Radio Shack don't seem to have any offerings either.
Arthur Bye
Posted on: 24 August 2003 by Onthlam
I failed to mention that the rig I found was $80 bucks...
At Sears...
The Craftsman 3/8 Microtork Torque Part 44593
25 to 250 in-lbs../ 3.61 to 29.03 Nm
Hope this helps........
Marc
Have an idea...
I just bought this wrench. I will not need it for at least 6 monthes.
I would suggest that we get this wrench to as many homes as possible. knowone needs to pay this much money when I could send it to the first person. Then the next person pays to send it to the next...and so on...
Let me know what you think..........
Marc
Posted on: 24 August 2003 by Tarquin Maynard - Portly
Originally posted by Marc Newman:
Mike,
Thanks,
Marc
well I do feel silly. A bit. You can see my point, though, er, off for some more wine methinks.
Thanks Marc
Mike
Posted on: 25 August 2003 by Martin Payne
Martin,
would it be possible to post them here, please.
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
