Denon 1910
Posted by: DelR on 27 February 2010
Just bought one of the above receivers.
I've connected my Sony BluRay player via a cheap HMDI cable I had left over, however I cannot get HD Audio, the display only says PCM is being received.
Would the cable have any bearing on this, as I have the player outputting via HDMI, and the amp receiving as Auto? Are older HDMI cables not HD Audio compatible?
Posted on: 27 February 2010 by RoyleBlue
Had a similar problem coonecting my Sony to a Yamaha - if I remember rightly its a setting in the Sony audio menu but can't fully remember which bit - will have a look tomorrow for you.
Posted on: 27 February 2010 by PureHifi
Probably 2 things to check...
A: If it happens to be a music movie disk you are watching, it may default to a stereo PCM sound track..
B: Most likely that you have not properly setup the blu-ray player audio output (if might have a downscale feature to stereo that you have previously had switched on ?)
Have a read of the manual of both player and receiver, and all should become clear as mud.
Posted on: 27 February 2010 by DelR
Thanks for your help.
As you said a bit more playing around at the DVD end and the HD Audio light lit up.
That saves a trip out on this very dreary Sunday.
