Robin Guthrie - Imperial
Posted by: iiyama on 16 June 2003
If you liked the cocteau twins and the 4ad sound then you should check this cd out.
Robin is the ex-guitarist of the cocteau twins and has created a cd of superb ambient tracks.
If you are familar with the cocteau twins (and you should!)then you will recognise his style, all the tracks are instrumental and folow a similar vein to the victorialand/ moon and the melodies cd's, with a hint of micheal brooke for good measure.
I think it is worthy of a listen if you like to 'chill' out!
