LP12 setup
Posted by: BigH47 on 27 January 2003
Having tried to understand the LP12 set up document, a couple of questions.( haven't done any thing to mine its as it came back from the dealer.)
MY understanding of the set up is that it is done in a support frame, the base being lined up with the sides and the frame horizontal both ways.
I set my TT support shelf level bothways.
Q1 What should I check on the LP12 for level the base or the turntable?
I ask this because the bottom cover is not in the setup(I think) and I can't believe those rubber feet are all exacly the same size so the TT will not be level.
Howard
LP 12/ Ittok LV 11 pre Cirkus
Arcam CD 72T
72/Hi/140 Black SNAIC5 NACA5
Linn Keosas. SO 5 tier. TT wall shelf.
Howard
Arcam CD 72T
