supercap
Posted by: Charlezz on 02 June 2001
Does a Supercap work with a Nac 102 ?
If yes, how ? (Which plug on the Supercap should i use??)
Thank you in advance.
Charles
[This message was edited by Charlezz on SATURDAY 02 June 2001 at 23:31.]
Posted on: 02 June 2001 by davidf
charlezz, yes the supercap works with a 102. The 5 pin output(the first connector next to the napsc plug)goes to the the lower of the two 5 pin din plugs on the supercap (the first one from the left as you look at the back of the supercap). I had a 102/supercap before going to an 82/super. No question, it upgrades the 102 significantly more than the hicap. If you are seriously planning on going the 52 route, then this is a good interim move. Otherwise, I`d go for an 82/hicap next. Do you have a separate power supply for your 102? regards, david.
Posted on: 03 June 2001 by Charlezz
Ok David, now i am sure i can go for a Supercap...
I found last week a used supercap (5 y.o) for 1200£ and it is very rare here in France....
I have got a cd3.5/Nac102/Hicap/Nap180.
The Supercap will go with the Nac102 and the hicap with the cd3.5 (Many say that cd3.5/Hicap is as good as the CDX)
My next upgrade will be what i will find first: used 52, 135's, cdx/xps or even cds2/xps.
Charles
Cd3.5/hicap/Nac102/Supercap/Nap180 .... oh yeh man , it sounds well!
Posted on: 03 June 2001 by davidf
charlezz, How much is 1200 francs in US dollars? Sounds like a good move if it is a good deal because as you said, you can move the hicap to the cd player. Enjoy. david.
Posted on: 03 June 2001 by Paul B
Charlezz:
I used a 102 with a Supercap for about a year before moving on to a 52. The Supercap elevates the performance of the 102 significantly. You definitely will not be disappointed.
Paul
