iTunes & missing art work
Posted by: badlyread on 01 November 2009
Hi All
Still ripping to the Mac Mini but have encountered a little, but annoying, problem. Some of my album art work is missing. I have checked the box for Apple (Gracenote) to do most of the work for me but the usual method of getting missing stuff is not working: Highlight tracks>get info>drag artwork to box and watch the blue line fill. Since going to iTunes 9.0.2 this does not work.
Any help much appreciated.
Neil
Posted on: 01 November 2009 by paremus
Neil
Which format are you using? AIFF, WAV or ALAC. I had this problem with WAV - converted the offending files to AIFF and album art work attached fine.
Richard
Posted on: 01 November 2009 by badlyread
Using Apple Lossless. It was working fine if a little slow with the Screen Sharing, but working.
Posted on: 01 November 2009 by garyi
The little box you add it too, make sure its on 'currently selected' and not set to 'now playing'
You can determine this by a tiny triangle that sits just above it. Not great.
Thanks Garyi that works. There is always more than one way to do things with Apple.
Posted on: 02 November 2009 by badlyread
Ok. So how do I remove the wrong artwork that iTunes has collected?
Neil
Posted on: 02 November 2009 by winkyincanada
Yeah, I managed to drag the new image to the little box OK, but it still keeps using the old one in cover-flow. I can switch between the two images in the little box using the tiny arrows above it, but it makes no difference to what is displayed in cover-flow.
Any help appreciated.
Posted on: 02 November 2009 by Eloise
To remove incorrect artwork in iTunes, highlight the tracks within the CD and right click (Ctrl-Click) and choose get info. Put a tick in the artwork box and click okay. All artwork will then be deleted.
Eloise
Posted on: 03 November 2009 by badlyread
That seems to work nicely.
Many thanks Eloise.
Neil
Posted on: 03 November 2009 by winkyincanada
Yep, worked for me. Thanks a lot, Eloise.
