Remote control weirdness
Posted by: Somesuch on 09 January 2003
I have a "Dual Remote" that behaves a bit oddly. Sometimes, after changing a track on the CD player, the volume buttons won't respond. I have to toggle between "CD" and "Preamp" several times, and maybe whack the remote a couple times to get the volume to change.
THis actually occurs with TWO remotes (each one resides at a different seating position in this room). So is this a known problem with the remote design? Or something wrong with my preamp (it's a 52)? I've put fresh batteries in each remote, and ensured a clean line-of-sight and everything.
Any help greatly appreciated.
E.
Posted on: 09 January 2003 by ray dodd
This may not be the answer but I have always found that the battery connections are not always the best on remotes......if poss try the remote whilst 'fiddling' with batteries.
Just a thought !
Posted on: 09 January 2003 by Martin Payne
I had something similar with my 52 (and a friend has it really bad with his 82).
The front-panel electronics sometimes get confused by lightning/static. Switch the preamp off for 10 mins.
I suspect the abuse of your remotes is only hastening their demise, not solving the problem!
cheers, Martin
Posted on: 09 January 2003 by Bob Shedlock
It could also be an indication that the optical coupler for switching in your preamp is about to take leave. Not a good thing at all.
Posted on: 09 January 2003 by Somesuch
Well, *I* feel better for it, anyway, heh heh. heh.
Oh dear. So...something expensive to fix?
Thx,
E.
